Colored rotor bolts- Mtbr.com
Results 1 to 11 of 11
    Colored rotor bolts
    I have seen some bikes with colored brake rotor bolts, and it looks pretty cool.
    I assume they are anodized aluminum.
    So I ordered some from Torontocycles.com. On their website, they don't call them rotor bolts, but they are the right size and have the torx head.
    So, after I ordered them, I started thinking that they probably don't call them rotor bolts for liability reasons, since they are aluminum in a rather high stress area.
    Are the bikes I have seen actually using anodized aluminum rotor bolts, and is it safe to do so?
    conjoinicorned
    Reputation: ferday's Avatar
    Quote Originally Posted by smilinsteve
    i'm pretty sure what you saw are anodized ti bolts...i've never personally seen alu. rotor bolts but that doesn't mean they don't exist
    i would personally never use aluminum in that location for more than one reason. although truthfully you'll probably not have any issues.
    edit: just noticed that they do in fact carry alu. "rotor bolts".
    what would rainbow unicorn do?
    Reputation: mtbmike0311's Avatar
    Have you thought about having your bolts anodized locally? I don't think I'd gamble on using bolts that are not specifically designed for brake rotors. There's a local place where I live that will anodize an entire hardtail frame for about $100.
    Quote Originally Posted by ferday
    Who is they?
    Quote Originally Posted by mtbmike0311
    Well, I assume my current bolts are steel, and you can't anodize steel. I thought about painting them but the color would probably scratch just from tightening.
    conjoinicorned
    Who is they?
    LOL
    um...i suppose torontocycles, as you mentioned...
    honestly the chances of all 6 bolts failing simultaneously are not good. ride em hard and report back!
    Anodized Stainless Steel Rotor Bolts...
    http://tbsm.com.au/index.php?main_pa...oducts_id=2840
    Quote Originally Posted by edzwa
    Hmm, so, I guess you can anodize stainles???? I checked a few websites that say you can't, and I read in another that it is often done by depositing a thin aluminum coating first, and its not so durable, but anyway......
    That makes me more wary of my aluminum bolts, as the colored rotor bolts I have seen on other bikes may not have been aluminum at all....
    Quote Originally Posted by smilinsteve View Post
    I am the idiot who strarted this thread, so I figured I better put in a public service anouncement here:
    Don't use aluminum bolts for rotor bolts!
    I installed a rotor a couple of months ago and came up one bolt short, so I grabbed one of the anodized aluminum bolts I had for the 6th hole. I figured 1 aluminum bolt isn't going to cause a failure with 5 steel bolts in there.
    I was right, it didn't cause a failure, but the head of the aluminum bolt sheared right off, even with 5 steel bolts holding that rotor tight. If all 6 bolts were aluminum, I am fairly certain that rotor would rip right off the hub.
    My colored aluminum bolts that look like rotor bolts work great for water bottle mounting bolts. That's all.
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    Get anodized titanium rotor bolts.
    http://www.imperialbikeco.com/produc...tml?fullSite=1
    B A N N E D
    For the cheapest & easiest way to color bolt heads click here.
