code /elixer lever assembly swap out- Mtbr.com
Results 1 to 3 of 3
    is it possable to use the code caliper with a elixer lever or avid 7 ?
    i have busted the lever internal of my codes in a crash and was thinking of swapping out the lever assembly out for an elixer or juicy 7 lever assembly.
    Chances are good that it is possible, it depends a bit on the leverage ratios if it results in a usable configuration (i.e. you get proper lever travel before engagement). At least from a chemical point of view there is no concern as both use DOT oil. I'd just try it and see if it works.
    err, 27.5+
    Reputation: AL29er's Avatar
    Yes, either Juicy or Elixir lever will work fine with the Code caliper. Juicy is a direct swap. Not sure if the Elixir uses the same hardware at the lever though, never done that swap personally.
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
