code brakes- Mtbr.com
Results 1 to 7 of 7
Thread: code brakes
    code brakes
    How are hard/easy are they to bleed?
    Any issues with air getting trapped in the caliper?
    Nov 2006
    Use the kit, it's a no-brainer. Five minutes for a full bleed, 10 minutes if you're anal and tapping the lines like me. Use Motul DOT 5.1 (not 5, that is a silicone based brake fluid), if you use DOT 3 or 4 you will be downgrading the performance of your very expensive brakes. I bleed Hayes discs all the time and the Avid bleed kit is a very comprehensive and well-thought out kit, I hope that Hayes takes note of this.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Any glycol based DOT 5.1 is fine. I believe they come pre-bled with DOT 4. My personal preference is Motul.
    Hayes brakes are much easier to bleed with a syringe.
    BOSS TYCOON
    Sounds like a good idea for my 7's, but Motul? Isn't that motor oil? How does that work compared to 5.1?
    Meh.
    Motul is not just motor oil. Motul makes all sort of performance fluids.
    DO NOT put motor oil in your brakes.
    I've read this alot...........
    Regarding Motul brake fluid. What makes Motul 5.1 better than other brake fluids? What performance advantages does it give.
    I'm asking because I am always looking for ways to increase braking performance.( I just installed a set of codes)
    Did not mean to hijack the thread, sorry.
    Meh.
    DOT 5.1 is less viscuous than DOT 3, in some cases, half the viscosity of DOT 3. This means the lever pull is easier, and the piston response is better.
    But the primary benefit is that DOT 5.1 has a much higher boiling point than DOT 3 or 4. This means that you will experience less fade. You can brake harder and longer.
