Clarks Skeletal Hydraulic; Seperating Disc Pads for Fitment- Mtbr.com
Results 1 to 7 of 7
    Site Owner
    Reputation: brumbrum's Avatar
    I've made a bit of an embaressing bo bo and pulled the lever on my hydraulic brake kit before fitting it. The caliper has now pushed the pads together leaving no room to slot the disc rotor. what do i need to do to seperate the pads / caliper spacing?
    New without a clue,
    Andrew
    Reputation: Neily03's Avatar
    Feb 2010
    Carefully with a small flat screwdriver.
    Site Owner
    Quote Originally Posted by Neily03
    Unfortunately that does not work. The kit is already full of dot 4 fluid pre bled. Will i have to drain out the fluid first and then seperate the pads?
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by brumbrum
    No. Find a flathead screwdriver, press it between the pads and spread them apart. It will work. If if doesn't, you're not doing it right.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Site Owner
    ok, thanks. i will try again
    Cheers
    Andrew
    Big Gulps, Alright!
    I've heard of people using a deck of playing cards too. Place some cards in and keep adding cards until they're pushed apart. No idea if this works though, and seems rather long and unnecessary.
    Site Owner
    you were right, i was wrong. it was just a matter of finding the correct spot to lever the pad. Once found it eased apart. thanks for the tip and patience
    Andrew
