can sum1 send me a link for a brake adapter for a boxxer- Mtbr.com
Results 1 to 6 of 6
    I have a 2009 boxxer world cup and im having trouble finding a brake mount.
    I have a 203mm disc and the brake caliper is a 51mm mount. The fork has a 51mm mount as well. Please if anyone knows where i can get one it will be greatly appreciated.
    I have shimano deore XT hydraulic brakes.
    B A N N E D
    hey thanks for that but thats the wrong part. It wont fit a boxxer and then the shimano deore XT because its at a different angle.
    Im thinking this might work but I dont wana buy it and have it not work and it doesnt say what the caliper and mounting size is. I hope its 51mm for both but it might be 74mm
    http://www.mtbbike.org/rock-shox-boxxer-2/
    ballbuster
    Reputation: pimpbot's Avatar
    Not with that title.
    B A N N E D
    Quote Originally Posted by nhillerby
    Have a better look at the link.
    Disc mount adaptor required to fit an International Standard 51mm XT Disc Caliper to a 51mm international standard Rock Shox Boxxer Fork mount to accomodate a 203mm Disc Rotor.
    Please note this adaptor with work with the Rock Shox Boxxer Fork only
    Does it mention 74mm anywhere ?
    74mm = PM (Post Mount)
    51mm = IS (International Standard Mount)
    Older Boxxer Mounts are IS - 51mm but are set up at a different angle to the normal IS mounts on most forks, the normal 51mm IS adapters won't work on Boxxer forks.
    New Boxxer mounts are 74mm - PM
    Aug 2010
    Quote Originally Posted by pimpbot
    Y not? Y U H8in'?
    And while you're up, can somone get me a drink from the fridge (already!!!)?
