• 10-03-2008
    bahamabluez
    Can I.S. style disc brakes be adapted to fit 74mm post mount disc brake fork?
    Just wondering if you can adapt IS mount disc brakes to a 74mm post mount disc brake fork? thanks
  • 10-03-2008
    Bikinfoolferlife
    Are you sure your brakes are IS only? Many are actually post mount that need an adapter to run on IS mounts....what brakes do you have?
  • 10-03-2008
    bahamabluez
    Shimano m486
  • 10-03-2008
    timehoc
    yes there is an IS to PM adapter but you'll have to go up one rotor size though
  • 10-03-2008
    Bikinfoolferlife
    Originally Posted by bahamabluez
    Shimano m486
    Looks like they mount right up, here's the instructions http://techdocs.shimano.com/media/te...9830651792.pdf
  • 10-04-2008
    Squash
    Bikinfool is correct...
    the M486 is a post mount caliper. So unless you are mounting them to an IS mount fork or frame, or using larger than 160mm rotor on a post mount fork you won't need an adapter.
    Good Dirt
