Can this frame work with 140mm brakes/rotors?- Mtbr.com
    Reputation: fueledbymetal's Avatar
    Is there anything I can do to make this frame accept a 140mm rotor? It currently has a 160mm brake.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    In a word, no. Not really any modification that can be made without damaging the frame. You could try removing the CPS spacers but I doubt that would even give you the clearance.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    T.W.O.
    Reputation: mimi1885's Avatar
    even if you can clear the 10mm the 140mm rotor required, the question is why? It's not that much lighter, and you are giving up quite a bit of power as well, heck the rotor is smaller than the 34 cassette I have 140 set up before and in the end it's just not worth it.
    Is it weight saving you are looking for, it's not really there.
    Thanks, I was afraid of that. My main bike has 140mm rear's & I'd like to be able to more easily swap wheels. I only weigh 144lbs & haven't had any problems with the braking power of the 140mm, so I'd like to keep using them.
