Caliper bolt won't go into front fork what to do?- Mtbr.com
Results 1 to 13 of 13
    As seen in the photos my caliper bolt that goes into the fork is stuffed, i believe it does not have any more thread left inside? but anyway i can not screw it in any further and this means the bolt is very loose. This is extremely dangerous.
    Since it's going into the fork how can i fix this problem i cant just drill other hole? do i have to get a hole different fork now? :O
    Any solutions would be helpful. Thanks.
    Attached Thumbnails Attached Thumbnails Caliper bolt won't go into front fork what to do?-dsc00030.jpg
    Reputation: shiggy's Avatar
    Dec 1998
    Get a shorter bolt.
    Add more washers under the bolt head.
    Shorten the bolt.
    Take it to somebody that knows what they are doing.
    mtbtires.com
    Tribe of one
    Reputation: bike flyer's Avatar
    Any chance you have the top bolt in the bottom and the bottom bolt in the top?
    Reputation: Aresab's Avatar
    I agree with the others, shim it with washers. Hopefully, you did not strip the threads, however if you did, a 6mm helicoil works fine to repair, speking from experience...
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by RSabarese
    Hopefully he didn't torque it so hard that he cracked the lowers. Seen that before...
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Quote Originally Posted by Berkley
    Ah yeah that does sound like what i did lol. I was centering my brakes and tighten it up real hard. Thanks for advice.
    EDIT: Just tried adding some extra washers, no luck. The bolt does not even stay in. It looks to me the inside thread of the fork is completely striped.
    RSabarese what is a 6mm helicoil?
    Reputation: 006_007's Avatar
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Quote Originally Posted by bike flyer
    ^^ this
    After you helicoil it, don't be a gorilla when you tighten the bolt. It doesn't have to be much beyond good and snug. If you have a torque wrench, use it to torque the bolts to about 5 Nm or so.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Quote Originally Posted by wv_bob
    ^^ this
    Hmm i see. What size would it be? 6mm?
    I'm guessing it's an M5 bolt. Take it with you to the hardware store when you go to get the helicoil and they'll match it up for you.
    Reputation: scooter916's Avatar
    all brake mounts are m6
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    Cheers guys.
    Sorry for the late response, but it looks like your on your way to a 6mm helicoil. Once you get the helicoil, foll the directions to a tee. Should take 15 minutes and you'll be good as new.
