Brake and removing tire question- Mtbr.com
Results 1 to 9 of 9
    May 2010
    I have avid single digit ti v brakes and everytime i remove a tire the brakes "loosen" up. At first i would barely have to pull on the brake to make my bike stop but now i have to pull all the way back. Does anyone know what is happenign? How to fix it. I have an 08 Rockhopper if that matters
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    hmmm, weird, nothing should change.
    Are all of the housings in their proper stops?
    do you undo the noodle before wheel removal?, or do you force the tire between the pads?
    Honestly... ahh I give up
    May 2010
    Yes i undo the nooble before removing the wheel. and not sure what housings are?
    ~Disc~Golf~
    Quote Originally Posted by david123
    The sheath that holds the cable
    May 2010
    it looks like it is in the correct place. I saw an allen wrech screw that was loose so i tightened it up and now my from right brake is sticking to the rim..
    Reputation: shiggy's Avatar
    Dec 1998
    That is to center the brake. It should be neither tight nor loose. Adjust it so the brake does not rub on the rim.
    I suspect the cable housing has come out of one of the stops on the top tube.
    mtbtires.com
    ~Disc~Golf~
    Quote Originally Posted by shiggy
    or even possibly, the housing ends weren't flushed properly, or the ferrules and/or housings weren't seated in the stops correctly at the time of the original install.
    OP, make sure the cable runs are correct and everything is in place - If it's still loose, pull the slack out at the brake arm (loosen pinch bolt, pull cable, retighten.)
    May 2010
    Quote Originally Posted by highdelll
    This is what the guy at my LBS shop told me to do. Im just nervous that i may do it too much and mess it up. Im pretty sure i stripped the break caliper tightening that screw too much that i thought was loose When i went to the LBS to get the guy to tell me what is wrong with it. I asked him if i could watch what he did so i could do it myself if it ever messed up again. And his response was "No! I'm not here to teach you a class on how to fix your brakes!" Real ***hole.
    ~Disc~Golf~
    Yeah. what an A-hole...
    Listen, ya gotta learn to do this shyte yourself...
    Start by reading up at parktools )http://www.parktool.com/repair/readhowto.asp?id=21 - Pay no mind w/ the 'required tools' AND then then come back with questions.
    -Bueno Suerte!
