brake levers for disc road calipers- Mtbr.com
Results 1 to 8 of 8
    Teen Wolf
    Reputation: cr45h's Avatar
    I have a Raleigh Furley with promax 720m RA disc brakes. I am thinking about putting a flat bar on it and getting rid of the drops. Would a standard MTB brake lever (avid speed dials) work with these "road" style calipers? Or do I need to look at replacing the calipers with something else? I don't know the difference between the road/mtb versions of disc parts, so I'm not exactly sure what I need.
    B A N N E D
    MTB brakes are long pull.
    Road brakes, cantilever brakes & BMX brakes are short pull.
    Speed Dial levers aren't designed to work with short pull brakes.
    Shimano BL-R550 or the Sram 700 flat bar lever would be better choice.
    I'm sure that other brands make similar levers.
    Teen Wolf
    cool, thanks for the advice. i'll look into those other levers, or maybe i'll just throw some bb7's on it for a nice little upgrade.
    Teen Wolf
    not to be ignorant or anything... but wouldn't using a long pull lever from a MTB work just fine with a short pull caliper? if it's set to move more cable, wouldn't it more quickly be able to close a road disc caliper?
    dru
    dru is offline
    Quote Originally Posted by cr45h View Post
    Yes, it will 'close' the caliper quickly but have no power.
    Drew
    occasional cyclist
    Teen Wolf
    Quote Originally Posted by dru View Post
    Drew
    ah, ok. i dont get why it wouldn't have power but ill take your word for it. thanks for the reply.
    dru
    dru is offline
    Leverage my friend! They are called levers for a reason. More cable pull = less force applied to the arm of the caliper. Less cable pull = more force. The fulcrum of a lever determines force to a degree (along with other factors). The fulcrum is the pivot. The cable is further away with long pull and closer with traditional canti/bmx/road levers.
    Drew
    occasional cyclist
    Teen Wolf
    oh, right on! thanks
  1. compatible disc calipers for shimano m775 levers?
    By gauncher in forum Brake Time
    Last Post: 04-17-2013, 05:44 PM
  2. Replies: 1
    Last Post: 12-02-2012, 03:55 PM
  3. Mixing XT brake calipers & levers
    By 650bee in forum Brake Time
    Last Post: 05-08-2011, 03:36 PM
  4. BB7 MTB calipers with some road levers??
    By driver145 in forum Brake Time
    Last Post: 04-14-2011, 11:36 AM
  5. Deore M595 calipers with servo brake levers?
    By dblspeed in forum Brake Time
    Last Post: 04-14-2011, 12:34 AM
