Brake installation- Mtbr.com
Results 1 to 6 of 6
    Mar 2014
    Brake installation
    Hi, quick question. How much money does it usually cost to install new hydralic brakes. I currently have cheap mechanical ones and I want to upgrade to the hayes stroker trail brakes. They would probably need to be bleed and stuff.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    New brakes shouldn't need to be bled. If the hoses are the correct length already, they are a breeze to install and adjust - especially if your old rotors are any good and you're keeping them for now. The easiest scenario is just four bolts per brake. (Two at the clamp, two at the caliper.)
    Mar 2014
    Ok, but don't the hoses usually come to long
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by Saul Lumikko View Post
    Numerous upgrades that I have installed have always come with extra long brake lines presumably for an XXL frame. Each installation has required them to be shortened. At least if you want a clean looking cockpit and setup. Don't forget you're going to need to secure the brake lines to the frame in several locations. With all that being said, it's not difficult to do your own installation and even shorten the brakes lines if necessary. Several threads on here for doing both.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Reputation: hankscorpio's Avatar
    Jun 2012
    I just did my own with no experience and it worked out well. FWIW my lbs said 15 per brake if I bought them from the shop and $25 per brake if I brought them in myself because they would want to do a fresh bleed.
    Most shops will shorten and rebleed for around $25 per line. Most times they also make sure the brakes are aligned properly.
  1. Shimano Brake Caliper Adapter Installation
    By dshoe70 in forum Brake Time
    Last Post: 11-12-2013, 01:19 AM
  2. Cantilever Brake Installation Issue
    By campybrooks in forum Brake Time
    Last Post: 11-02-2013, 08:57 PM
  3. Brake installation question
    By Camber11 in forum Brake Time
    Last Post: 10-15-2012, 06:00 PM
  4. Brake advice - upgrade and installation
    By gunsnroses in forum Brake Time
    Last Post: 09-12-2012, 09:54 AM
  5. Brake installation help
    By naiku in forum Brake Time
    Last Post: 07-13-2012, 07:10 AM
