Brake cable routing- Mtbr.com
Results 1 to 8 of 8
    May 2010
    Brake cable routing
    So how do you like to have you front brake cable on you bike? Fell free to explain why you have it a certain way?
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    your cable is way too long, you need to shorten it ... I always run mine on the inside of the fork
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    May 2010
    thats factory stock and it hydraulic brakes so i would have to bleed the system after.
    Nov 2007
    yes you will need to bleed them after you shorten the hose ... that just looks dangerous to me
    May 2010
    ok can i do it my self or take it to a shop?
    Nov 2007
    its pretty simple to do it yourself and if you need some "how to" info click here
    I AM I AM
    Reputation: ducktape's Avatar
    Yes I would recommend shortening it. If you haven't dealt with hydro brakes before you might want to get the LBS to do it, but ultimately it's not a bad thing to at least learn how to bleed them yourself.
    I like to run my front brake lever on the LHS so that I get a nice loop of brake hose up front (similar to what your other cables look like).
    May 2010
    can you post a pick of how you do that and i will do the same thing.
