Results 1 to 8 of 8
    just ride
    New question here. Better pads for my RX
    My stock pads are worn down and they tend to overheat easily... any suggestions for replacement pads? I've heard of organic... Please advice, thanks!
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    What brand and model are you braking on
    Formotion Products
    http://www.formot
    just ride
    I have the formula rx with alligator serration rotors 160mm. The pads are stock. Idk what brand is available in the market. Just seeking for a longer lasting, less chance of fading pads. Thx
    I got these in "burly" to replace my stock RX pads:
    http://www.brake-authority.com/index_gb.html
    So far so good, and they're less noisy than the stock pads. Can't comment too much on longevity as have only had them in a couple of months but they're the longer lasting versions from Brake-Authority.
    Jan 2005
    Longer lasting is a Sintered pad, less fade Semi Matallic; If your hittin steep DH trails work on pulsing the brakes off N on. Check caliper alignment and pad contact using feeler gauges to adjust the pad travel
    Formotion Products
    http://www.formot
    just ride
    So I'm looking at getting the semi-metallic. Do you guys know which pad the stock 2011 formula rx has in it?
    Reputation: BitterDave's Avatar
    Nov 2007
    Does the RX use the same pads at the One/Mega/R1? If so, then check out the comments on this thread: http://forums.mtbr.com/showthread.php?p=8300975
    Nov 2007
    Quote Originally Posted by Tjay View Post
    Sintered pads have a bronze colored backing plate. Organic pads have a black colored backing plate.
    "Organic compound offers better initial bite than sintered metallic and is found stock on R1 and RX model"
    "Sintered metallic pad compound resist heat better than organic and offer better modulation."
  1. What are 'fixed pads' and 'floating pads' ?
    By Soviet123 in forum Brake Time
    Last Post: 10-13-2008, 09:16 PM
  2. Knee Pads/Elbow Pads???
    By trek7100 in forum Beginner's Corner
    Last Post: 06-11-2008, 01:03 PM
  3. Replies: 36
    Last Post: 03-28-2008, 07:29 AM
  4. Avid bb7 pads - anybody used the ritchey pads?
    By asyluminc in forum Ritchey Design
    Last Post: 02-02-2008, 06:47 PM
  5. XT pads not touching rotors after resetting the pads, plz help.
    By big_mountain_biker in forum Brake Time
    Last Post: 01-07-2008, 02:26 PM
