Best way to bleed Avid brakes?- Mtbr.com
Results 1 to 11 of 11
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Can the hose be cut without bleeding?
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Sheffield,South Yorkshire
    Reputation: ibbo's Avatar
    In a word No.
    What is the bleed procedure, if I were to cut the front hose?
    You need the avid bleed kit.Then type Avid bleed video into youtube and there's a couple that take you through it step by step.
    ...idios...
    Reputation: SteveUK's Avatar
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/xUumuMIo6Ok&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/xUumuMIo6Ok&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    Diogenes
    Former Bike Wrench
    With the Avid Bleed Kit it is a 5 min (including setup time) mess free job
    According to the video...the guy cut the hose w/o bleeding it. How is that?
    ...idios...
    He doesn't show the process in that video, but at 3.10 it says "proceed to bleed".
    Diogenes
    Jun 2005
    Hey guys. I hate to be the bad example, but... I cut my rear Avid Elixir R line without bleeding it. I was careful to keep the line pointed upward, and I lost virtually no fluid. I put a dot of DOT on the cable before I rethreaded it into the lever. I readily confess that I'm a hydraulic brake noob. I bought a bleed kit assuming that I'd have to use it. But after I put everything back together, I felt like the lever action, engagement, and pressure were still great. I'm sure it can't be like that every time, but it was nice this once.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Quote Originally Posted by coombs
    As said it can be done if careful even by a noob.
    Formotion Products
    http://www.formot
    you can cut your lines without bleeding them... just have to be careful! Ive done it many times with success. I even checked my work by hanging the bikes from a hook to make sure the lever didnt get soft.
