BB7's with Tektro levers....- Mtbr.com
Results 1 to 5 of 5
    I have a 2010 SE Stout, on a whim I ordered a set of 185mm BB7's. Can I get by with the Tektro pulls till I get some that are better suited to the brakes??
    Reputation: mtbnozpikr's Avatar
    As far as I know it doesn't matter what levers you decide to run with a mechanical disc brake because they all do pretty much the same thing: pull the cable via connection to the cable and leverage.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by ///MikeD
    Tektro makes a lot of different levers.
    Any V-brake type levers works with BB7s.
    mtbtires.com
    Quote Originally Posted by shiggy
    I figured as much but it doesn't hurt to ask. I didn't want to install everything the BB7's then find out I have to put the stockers back on.
    I should have them in a week or so, pics(finally, of said SE) and reviews then.
    Reputation: phoenixnr's Avatar
    Avid speed dial levers. Better modulation in my experience.
