BB7 pictures! PLEASE HELP!- Mtbr.com
    Reputation: ATLien's Avatar
    Hello, I am trying to install my first set of dick brakes, and I am having trouble getting the brakes calibrated. Can someone who has disc brakes that are setup correctly please take a birds eye view picture of the rotor location inside the caliber. I just want to see how you have it spaced.
    I would really appreciate it if I could get a few pictures thank you.
    -Chris
    Bike and Ride Pictures
    Do not go where the path may lead, go instead where there is no path and leave a trail.
    - Ralph Waldo Emerson
    Home Trail:
    Blanket Creek (Woodstock, GA)
    neutiquam erro
    Reputation: Chris130's Avatar
    Mar 2005
    Well, I could post pics, but I'm not sure how much it will actually help. Not being a smart-@ss here, but are you very carefully following the calibration instructions from either Avid or Park Tools? I was having setup problems a while ago, but I also was half-@ssing some steps, and until I took 'em off and started over completely from scratch and followed the instructions to a "T", I had no success. Now, they work like a champ. But back to the pics... It's going to depend on your set-up. What spacing works for one dude may not work for you (depends on cable tension and how much/little slop you like to have in your brakes). Follow the starting-point recommendations from Avid for pad spacing ratios and then tweak from there. It takes a bit of trial and error. Even when I had it dialed in on the stand and a couple of laps around the parking lot, I still had to fiddle slightly during the first ride on the trails. Be patient. Making sure the caliper was mounted (and aligned) properly was the key for me.
    Cheers, Chris
    Meh.
    Reputation: XSL_WiLL's Avatar
    thanks for that link, that helps alot.
    -Chris
    Home Trail:
