Results 1 to 9 of 9
    Suffers From Binge Biking
    Reputation: marsh rider's Avatar
    BB7 MTN vs. Road Brakes
    Can someone explain what the difference is between the road and mountain versions of Avid's BB7s? The Avid site doesn't really mention what the difference is. Has anyone here ever even seen a road bike equipped with disc brakes?
    If it ain't broke, fix it 'till it is.
    Aug 2005
    some cycolcross bikes use discs, cometetive tri and road racers cant use them because rules sanction against them for safety reasons.
    iirc the difference is that mtb versions work with levers designed for v-brakes, and the road ones = canti's. the amount the cable is pulled by the lever determines what ratio brake force is applied with.
    I'm curious, what would those safety reasons be?
    ballbuster
    Reputation: pimpbot's Avatar
    Somebody...
    Quote Originally Posted by General Hickey
    ... might be in danger of winning by actually having brakes that still work in mud and wet.
    They allow disc brakes in the lower classes, but not the more compeditive classes, so actual safety has nothing to do with it.
    Yeah, welcome to the mind of the UCI.
    As they say, you know it works because the UCI banned it.
    Five is right out
    Quote Originally Posted by pimpbot
    Just like recumbents... but let's not get into that
    Reputation: boomn's Avatar
    Quote Originally Posted by womble
    Well I can be thankful for that correct decision at least
    Yeah, I didn't want to say it, but I suspected as much.
    Thanks for the replies, you all just saved me from making a wrong choice Looking at the two now, I hadn't even noticed the different position of the actuating arm between road and mountain.
    Aug 2005
    i think it was something to do with the idea that it could be used as a weapon to slice a person infront of yous' leg, accidental or not. just easier to ban them all together and not worry about the details later. but to be honest, i dont know all that much about road biking, just the fact that some sanctions do not allow discs.,
