Avid Rotors with Shimano Brakes?- Mtbr.com
Results 1 to 10 of 10
    Apr 2014
    Can I use these:
    Brand New Avid G3 CS Disc Brake Rotor 160mm 6" Pair 1pcs Disc 6 Blots BB5 BB7 | eBay
    with Shimano Deore brakes? And should I be wary of buying brake rotors from China? Seems like a steal, but could be too good to be true.
    If there's no mountain, it's just biking.
    Evolutionsverlierer
    Reputation: acer66's Avatar
    Oct 2010
    Not sure yet but we are trying that right now with slx brakes and avid rotors since they seem to be very similar to shimano rotors.
    Reputation: Mr Pig's Avatar
    Works fine, done it a couple of times and running it now.
    Evolutionsverlierer
    Oct 2010
    Cool, good to know that at least some avid stuff is actually good for something.
    Reputation: watts888's Avatar
    Oct 2012
    I have similar ones from amazon. They're definately not genuine, but they work. Takes a litle extra time to bed them in properly, but they'll get there.
    Quote Originally Posted by acer66 View Post
    I originally tried the Avid HS1 rotors because Shimano brakes were prone to being noisy. Turned out it was just the rotors as HS1 rotors are silent, mostly.
    Avid is spelled wrong, there shoild be an 'O' in there.
    Apr 2014
    "Avid is spelled wrong, there should be an 'O' in there."
    That is why I'm going with Shimano brakes I've got Avid Elixer Front brakes and Shimano Deore Rear on my hardtail right now. I like the shimanos much much better.
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    I have chinese HS1 rotors on deores right now, and its works flawlessly. Cant beat the price. I bought a ton of spares.
    Quote Originally Posted by GuitsBoy View Post
    I have Chinese HS1 rotors on deores right now, and its works flawlessly.
    I have both genuine HS1 and Chinese ones. You can see the differences when you examine them but in use I can't tell the difference. They both work fine.
    Reputation: Davide's Avatar
    I seem to have a different experience: I bought the HS1 to save some dollars when I got my XTR brake set. Very cheap and lighter by some grams they were fine for a while. then they started squealing and no trick (cleaning rotors, sanding the pads, new pads) fixed the problem. I suspect that they simply warp with use (the front gave into squealing about two months before the rear). Tossed the HS1 installed original Shimano XT IceTech and not only power and modulation went way up but there as been zero issues with noise,
  1. Shimano XT Brakes and Avid Rotors
    By jmiah in forum Brake Time
    Last Post: 08-28-2015, 08:55 AM
  2. avid rotors, shimano brakes
    By wjh in forum Brake Time
    Last Post: 11-20-2014, 04:26 PM
  3. Shimano rotors with Avid brakes?
    By bradkay in forum General Discussion
    Last Post: 12-18-2013, 11:07 PM
  4. Anyone Tried Shimano Rotors with Avid XX Brakes
    By chadadally in forum Brake Time
    Last Post: 07-22-2013, 12:59 PM
  5. Shimano XT m775 brakes with Avid G3 Rotors?
    By mrilo in forum Brake Time
    Last Post: 10-23-2012, 07:15 PM
