Avid mounting hardware?- Mtbr.com
Results 1 to 3 of 3
    For Juicy 7, what size torx bolts can you use?
    What size bolts do you use for caliper to adapter? Adapter to frame?
    Meh.
    Reputation: XSL_WiLL's Avatar
    You don't use torx bolts for the adapter or caliper. You only use t25 torx bolts for the rotors.
    Go to your LBS they should have plenty of bolts. Any bolts from v-brakes will work as well.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by dontomas
    All the mounting hardware is supplied with the brake.
    mtbtires.com
