    May 2010
    Avid mounting bolt kit?
    So i bought some used brakes, BB7 and rotors. The guy couldn't furnish any of the mounting hardware.
    Anybody every go down to the local nut and bolt place and purchase bolts for rotors and caliper mount . Good or bad idea?
    caliper mounts are probably ok to buy from a hardware store i bought pedal pins
    Reputation: GTscoob's Avatar
    Yep, I've had to do this a couple of times. If you've got another bike for reference, pull the bolts and measure the length.
    The thread pitch is standard metric. I think it was 50-60 cents for 2 bolts at my local Home Depot.
    You'll also need the CPS washers . . . which are just hemispherical washers from any old V-brake kit. You'll need 4 convex washers and 4 of the shortest concave washers, per caliper.
    Your local bike shop or bike cooperative should have tons of these on hand.
    Edit:
    Wow, Avid sells these kits for $5-7. Definitely go to the store and get the hardware.
  1. FR Shock Mounting Bolt
    By Kbrembo in forum Nicolai
    Last Post: 07-09-2010, 02:43 PM
  2. mounting bolt torque??
    By the_Alaskan in forum Diamondback
    Last Post: 04-01-2010, 04:42 PM
  3. Frozen Shock Mounting Bolt
    By w84wind in forum Specialized
    Last Post: 04-08-2009, 11:04 AM
  4. is there a mounting bolt in this picture?
    By Windjammer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-21-2008, 04:59 PM
  5. There is some play in my shock mounting bolt
    By wanderoo222 in forum Shocks and Suspension
    Last Post: 03-11-2008, 12:16 PM
