Avid Mechs on Formula hubs- Mtbr.com
Results 1 to 3 of 3
    Reputation: spangelsaregreat's Avatar
    New question here. Avid Mechs on Formula hubs
    Hi,
    My commuting bike currently has Formula MD1 disk brakes on it but they are coming to the end of their life. I am considering getting Avids as replacements, however, my hubs are Formulas with four holes instead of six.
    Would I be able to use the current Formula hubs and disks with the Avid calipers? Or do I have to convince the wife that I need new wheels as well (considering Mavic Crosslands).
    The Formula hubs are still going strong so it seems a waste to chuck them as well.
    Regards
    The MD 1 had 165 mm rotors and the Avid has 160 mm rotors as far as I know. The good part is that we do offer 160 mm rotors with 4 bolts. The rotors cost $ 33.00 each.
    Brakemeister
    On MTBR hiatus :(
    Based on Thor's comments...
    ...you have the option of putting a small 2.5mm stack of washers between the adapter and the Avid caliper to make up half of the 5mm rotor difference. This is assuming the rotor side-to-side offset is the same as IS (which I assume it is).
    You could also track down an old set of v1 Avid calipers which were built for 165mm rotors, but those are scarce.
  1. Avid BBDB compatible with 2004 XT Disc Hubs?
    By suichai in forum Brake Time
    Last Post: 02-11-2004, 04:38 PM
  2. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
  3. American Classic/WTB disc hubs
    By GrantB in forum Wheels and Tires
    Last Post: 01-19-2004, 08:44 AM
  4. Avid Cable Discs - Lever Compatability
    By MTBDad in forum Brake Time
    Last Post: 01-17-2004, 09:32 PM
