Avid Juicy Carbon- Mtbr.com
    Oct 2007
    Avid Juicy Carbon
    Hi,
    I'm putting my breakes on a new bike. The brake-hose runs through a taco on a Turner Flux, which means that neither the caliber or the brake lever can go through.
    Is it easier to unmount the hose at the caliber or the brake-lever? And is it possible to do without having to "destroy" any of the parts?
    Is it possible just to unscrew the banjo - screw it back on and bleed?
    I'm not sure what a "taco" is, but I'd go with the banjo option, then as you mention, bleed the brake after refitting.
    Feb 2007
    it's easyest to undo at the lever side and if needed bleed lever only
    thats what I do when fit rear brake and line goes through lefty clamps
    Oct 2007
    Thanks to both.
    I went with Zagi's advice, and it worked. Didn't spill any oil from the hose, but I lost a bit from the lever chamber.
