• 01-29-2013
    waldog
    Avid hose compatibility - Juicy hose on Code R?
    Hey people.
    So I have found a set of Code Rs to replace a set of Juicy 3s on my DH rig. The Codes are used, and sadly the rear hose is about 300mm too short.
    My question is, and sorry if it's a stupid one, but can I just re-use the hose from my Juicys? As in unscrew it at both ends and re-screw into the Code caliper and lever, then get it bled?
    From just looking at everything, it looks like it would work, I currently have Elixirs on my other bike, so the lever is the same, and just by eye balling both the connections look the same.
    Help please.
    Grant.
  • 01-29-2013
    MitchD
    Yes it is the same fittings on the hoses,the code uses a swivel banjo while the juicy has a threaded boss.You might ,might not leak because the aluminum sleeve on the hose takes a set and doesnt like to be disturbed
  • 01-29-2013
    waldog
    Hey
    Thanks for that.
    The code calipers don't have a banjo, it's also a threaded boss. So I guess it should work then.
    Grant.
