Thread: Avid-Hope setup
    fsr
    fsr is offline
    New question here. Avid-Hope setup
    I have an older front Hope hub laced to a Mavic 317 disc rim. it has a 185mm 5 bolt rotor attached to it. Currently has a Hope C2 caliber attached. I am considering installing an Avid mechanical brake that a friend gave me so that I can have matching Shimano xt levers which I really like. The rear brake is a V brake. This would be installed onto a Marz fork. I hate to lose the Hope hub wheel as it is quite light. Any one see any problems with this set up before i order an Avid adapter? Thanks, FSR
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    As long as the rotor diameter is the same you should be fine. XSL_WiLL would you like to add to this
    Meh.
    Reputation: XSL_WiLL's Avatar
    It's cool. Those older Hope rotors have a real wide blade on the rotor. I forsee no problems. Just be sure to remove any old pad residue left on them with 800 grit sandpaper and lots of water.
    Music & Bikes
    Reputation: fokof's Avatar
    Hope is making costom disks with different bolt pattern. I ordered a 4 bolts (Coda) disk for my mono mini to keep my DT/Hügi hub.
    http://www.hopegb.com/voir_mm2disc.html
    "There is a big difference between kneeling down and bending over" -FZ
