Avid G2 Rotors vs. Shimano Rotor on Centerlock- Mtbr.com
Results 1 to 10 of 10
    Reputation: MagyarBika's Avatar
    I am in the process of building up a light cross country Rocky/Element and realized that my Shimano XT center lock hubs are not compatible with my Avid Ultimate/G2 Rotors 160mm.
    Should I get the DT Swiss Center Lock Adapter or get new Shimano Rotors.
    Some of the Shimano rotors I have seen require I use resin pads, any thoughts on that?
    i ride bikez!!11!
    Avid now makes centerlock rotors that would be compatible with your Ultimates.
    Thanks for that. Another option I guess.
    Quote Originally Posted by MagyarBika
    Center lock rotors end up a little lighter than 6 bolt. I run kool stop pads on my shimano center lock rotors cause they last longer and work better.
    That's interesting. I would have assumed that they would be a little heavier because of the center lock ring. I guess you don't have the bolts which take away weight.
    Thanks for the input.
    How do they centerlock rotor weights compare with the 2-piece XX rotors.
    i ride bikez!!11!
    My 160mm XX rotor was around 95g, I've got to think the Centerlock rotors are quite a few grams more than that.
    Reputation: veritechy's Avatar
    I have shimano centerlock rotors and don't use resin pads. It works fine.
    Save the money and get the $10 origin8 6bolt to centerlock adapters from Jenson... Work just fine
    2010 Trek 4300 Disc
    Quote Originally Posted by xmynameisdan
    You also have to consider the extra weight on the hub where the 6 bolts screw into....
    The center lock splines are tiny compared to the bolt lugs.
