Avid Code 5 Keeps Locking Up- Mtbr.com
Results 1 to 7 of 7
    I've been running 2009 Code 5's for a few months now and they've been awesome to me for the most part.
    One new issue I've been having recently is that when my bike is upside down (for maintenance and stuff), the rear brake slowly seizes up for no reason and the lever goes completely slack. The bike is not sitting on the lever at all while it's upside down. This only seems to happen outside when the temperature is in the 50f (10c) and lower range. It usually takes me a couple of minutes of pumping the lever over and over again with the bike right-side up to get the brake working as intended again.
    The front brake does not do this, it works perfectly all the time in any orientation in any temperature (so far).
    Does anyone have insight into this?
    So I gather the caliper locks onto the rotor while the lever has a bunch of free play?
    You are not what you own.
    Quote Originally Posted by GoremanX
    I am betting and air bubble???
    Quote Originally Posted by juancancook
    That's exactly right
    Reputation: schneidie's Avatar
    Bleed them. You definitely have something funky going on with your brake fluid, be it an air bubble or contamination, I can't say.
    Build.
    Ride.
    Repeat.
    crap, I was afraid of that. I had the front one bled by the LBS when I shortened the hose, but the rear hose length was perfect so I didn't touch it. Saved me some money.
    On a side note, the factory Avid bleeding sucks. My front brake (which has been re-bled) feels perfect, my rear brake (which has the factory bleed) feels mushy by comparison.
    Quote Originally Posted by jeffscott
    'twas air in the caliper. Had them bled today, and now the brakes work better than ever.
