Avid BBDB- Mtbr.com
Results 1 to 15 of 15
Thread: Avid BBDB
    Bedwards Of The West
    Oct 2007
    Avid BBDB
    Anyone else have one of these early versions of the mechanical disc brake? I don't know much about it, but it is working sweetly on my commuter. I think it was the first 'ball bearing disc brake' (hence the name). It's got dual adjustment knobs and works as well as the BB7's I've used. I found it in the shop and threw it on... pleasantly surprised. I'm a little worried about finding pads for it though.
    (no excuse for that either)
    LDH
    LDH is offline
    Reputation: LDH's Avatar
    I believe it is identical to the bb7's up to the redesigned one with the square pad adjusters.
    Yes. There is the Type F (earliest) and Type N (later). The BB7 and BB5 came out when SRAM bought Avid.
    I have the Type N because they were 12g (per caliper) lighter than the other versions.
    The pads are everywhere because they the same as all BB7s or all Juicys. BB5s are a round pad, which is quite different.
    B A N N E D
    The BB7 Overhaul Guide the on the Sram website is actually a BBDB Overhaul Guide.
    http://www.sram.com/_media/techdocs/Avid%20BB7%20Overhaul%20Guide.pdf
    That'll probably give you an indication of how much difference there is between a BBDB and a BB7.
    No longer 26
    Reputation: G-Live's Avatar
    The original BBDB's used 165 mm rotors instead of the now "standard" 160 mm.
    G (I have 2 sets)
    You can't depend on honest answers from dependant hands...
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Yeah, but that's just a matter of the adapters and rotors they were speced with. That didn't make the calipers any different.
    bi-winning
    Reputation: rkj__'s Avatar
    Quote Originally Posted by cobba
    Your signature is a mess! Time to edit out those size=5 tags.
    The BBDB Type N in that manual requires the Avid MDT-1 special tool. The BB7s and BB5s were redesigned to eliminate the need for the tool.
    This covers the BBDB and BB7s very well. http://forums.mtbr.com/showthread.php?t=365630
    Oct 2007
    Cool, so I can throw BB7 pads in there? I haven't actually removed the pads and looked at the shape.
    Also, can I assume that the adapter for a BB7 will work if I want to go to a 180 rotor?
    BBDB= ball bearing disc brake
    (and being a former hayes cable pulled brake owner, trust me, the ball bearings made a BIG difference in feel)
    If steel is real then aluminium is supercallafragiliniun!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Hardtails Are Better
    No, the caliper was changed when they went to 160mm rotors. The IS brackets were not changed.
    I have been using the BBDB since year 1 and all versions of the BB7. To use the original caliper with 160mm rotors I need to file down the mounting bracket.
    mtbtires.com
    Oct 2007
    ^^ Do you file down both sides, or just one, to 'rotate' the caliper down a little?
    Would a 180mm BB7 adapter work to use the BBDB with a 180 rotor? Would I need to file that too?
    thanks.
    Dec 1998
    Quote Originally Posted by CommuterBoy
    thanks.
    You would need to file down the bracket a lot for a 180mm rotor. Only need to file off about 2.5mm for a 185mm rotor. The goal is to not have the pads hanging off the outer edge of the rotor.
    mtbtires.com
    Oct 2007
    So file, check, file, check...
    I will probably try this... I have 180 rotors and a bench grinder on standby. So standard BB7 adapters is what I want to start with? Even if I have to file 5mm, that should leave plenty of threads for the mounting bolts to grab.... (famous last words )
    Hmmm.
    I have BBDB Type Ns and they work on any 160mm rotor I have.
    I would expect the same for 180s.
    The proof is in the pudding.
