Avid BB7 fit on 2000 Trek Fuel 90???- Mtbr.com
Results 1 to 5 of 5
    Nov 2006
    I'm new to this forum and I need some advice. I've noticed that most adapters for Avid mechanicals are 51mm spacing on the rear. My mount seams to be only 44mm wide. What gives? Is there an adapter?
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    My understanding
    I believe certain Trek frames take a proprietary frame mount for disc brakes. Ask this question in the Trek forum here on mtbr and I would also recommend checking with your local Trek dealer.
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Yeah... as Bob said... Trek used a proprietary mount for which you should be able to get through your dealer... older frames used the Hayes 22mm mount.. that one requires another adapter or a special caliper...
    I found a pic... here's a pic of a Fuel 90's stays with the adapter
    Nov 2006
    Thanks for the info. I will check the trek dealer for the part.
