Avid BB5 to Avid BB7- Mtbr.com
Results 1 to 9 of 9
    Oct 2007
    I recently purchased a new bike (08 Specialized Rockhopper) that came with Avid BB5 brakes. I would like to move to BB7's. Do I need new cables and levers or can I just swap out the calipers?
    Mar 2006
    Your old cables and levers will work fine.
    Never worng!
    Reputation: Verewolf's Avatar
    If you do get the BB7 make sure you get the 2008 brakes
    as they have both an inboard and outboard adjustment knob.
    Fantastic brakes!
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Quote Originally Posted by Verewolf
    Fantastic brakes!
    I think they changed the shape of the knobs for 2008, but BB7s have always had inboard and outboard adjustment knobs.
    Karl
    The plough
    Reputation: vmajor's Avatar
    Oct 2007
    Indeed, the main visible difference between BB5 and BB7 has always been that the BB7 has two adjustment rings.
    V.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by kwarwick
    Karl
    True. The knobs are reshaped, plus the inboard knob now has a torx screw, allowing you to tighten/loosen it with a wrench. Much nicer than previous models where you had to jam your fingers in between the caliper and the spokes.
    Reputation: nspace's Avatar
    The 08' BB7's are nice because of the "window" area on the rear caliper that makes the pad adjustment much easier.
    Quote Originally Posted by mduck81
    You may want to throw on an SRAM flak jacket for the cable housing for the back brake. It gets rid of that squishy feel.
    Lead by my Lefty............... right down the trail, no brakes.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Bulk housing works fine. Just make sure the ends are cut nice and straight, open up the lining with an awl, and use some sort of lube (Boeshield, TriFlow, Rock N Roll Cable Magic) on the cable. It helps cut down on friction. Check the cable routing for any unnecessary bends or long loops or tight bends.
