Anyone run metallic front/resin rear (pads)?- Mtbr.com
Results 1 to 5 of 5
    Mar 2013
    I just went out on my first ride with my new bike and the new setup is easier than I'd like to lock up the rear tire.
    Old setup: Trek Superfly 100, 180mm front, 160mm rear, resin pads
    New setup: Stumpjumper Evo, 203mm front, 180mm rear, metallic pads
    Both bikes had a Purgatory front tire/Ground Control rear tire (the same exact tires moved from one bike to the next).
    Is anyone else using resin pads in the rear? I have a spare set, was thinking of using them on the rear and using take-offs as spares for the front. Any thoughts?
    Reputation: Tarekith's Avatar
    Mar 2005
    I used to mix and match all the time, go for it.
    Tarekith.com
    '17 Specialized Enduro Elite 29
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    I do this, makes for better feel at the limit. Use the metallics for longevity and more power, I'm 225#...
    Todd
    I am. I'm too cheap to buy F03C metallic pads for my XTs so I just got the B01S resin pads and installed a washer under my callipers to get the pads at the right position.
    That, and Shimano Aus is sold out of the F03C pads for ages now.
    Its nice, give it a go. Not grabby at all. Pads themselves wear faster, but less wear on your rotors.
    If you ride in the wet a lot, I might reconsider though. Resin sucks in the wet.
    Mar 2013
    However many miles on this setup since I posted it and I love it
  1. M785 - Metallic, now Resin pads - New Rotors?
    By Pelly_NH in forum Brake Time
    Last Post: 01-22-2014, 09:03 PM
  2. Are these resin or metal pads?
    By Gabe3 in forum Brake Time
    Last Post: 07-26-2013, 12:39 PM
  3. Metallic pads on shimano resin-only rotors?
    By One Pivot in forum Brake Time
    Last Post: 03-27-2013, 11:45 PM
  4. Jagwire Semi-Metallic Pads
    By RagerXS in forum Brake Time
    Last Post: 03-17-2013, 08:38 AM
  5. Resin or Metallic Pads for my XTR 988 brakes?
    By trojans1993 in forum Brake Time
    Last Post: 11-28-2011, 05:31 PM
