Results 1 to 7 of 7
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    that annoying squeal... errrrrr
    OK,I'm pretty damn good at mechanics and figuring stuff out, but, I can NOT for the life of me get rid of the brake squeal on my front brake.
    • changed...
    • rotors
    • rotor size
    • pads
    • pad materials
    • calipers
    • Caliper mount
    • cables
    • rotor bolts
    even tried that crappy "squeal out" stuff which worked for like 1 ride
    I'm beginning to think it's the fork and/or the hub...? anyone else running a Reba SL 29er with a hope Pro 2 hub? and can't get rid of the squeal?
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Jun 2010
    I've learned to love my squeal. It sounds like SquaaaAAAAAARRRkk on my bike. I like to think it helps keep the bears away.
    Oct 2007
    Quote Originally Posted by Oatbag View Post
    well the one good thing is it lets people on the trail know when I'm coming up behind them... but I'd rather have an old bike bell
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Harmonic vibration
    you could campfer the leading edge of the pads, or try some graphite powder (*note - a little goes a long way and you will initially have some decreased braking untill that beds in and is only temporary - water washes most off)
    I've been curious if some gasket material (for heads, manifolds etc) placed between the disc and hub would dampen harmonic vibrations for some people - I currently don't have that problem, but if I did I would certainly experiment w/ it.
    Honestly... ahh I give up
    Oct 2007
    Quote Originally Posted by highdelll View Post
    Harmonic vibration
    done that, put electrical tape between the pads and the caliper and it helps a tad, tried a few layers between the rotor and hub and also from the mount and fork.. no deal...
    Like I said, i'm usually pretty good at going through step by step and isolation the issue.. but I'll be damned if I can fid it here... I'm really beginning to think it's the fork/hub combo.
    Reputation: WVBikr's Avatar
    Then borrow or switch front wheels.
    Oct 2007
    Quote Originally Posted by WVBikr View Post
    ya,.. thought of that, but finding someone close with a 29er, same sized rotors, aligning then going for a ride long enough to seat them...
  1. Annoying ads...
    By Kona0197 in forum General Discussion
    Last Post: 05-08-2011, 04:14 AM
  2. super annoying squeal - HELP!
    By maximus06 in forum General Discussion
    Last Post: 02-23-2008, 06:11 AM
  3. Anyone else see this as annoying?
    By Mutantclover in forum Shocks and Suspension
    Last Post: 03-18-2007, 11:18 AM
  4. Annoying ads
    By Call_me_Clyde in forum Site Feedback/Issues
    Last Post: 11-24-2006, 07:43 AM
  5. Disc Brake Squeal - squeal like a pig fat boy
    By JerryBoneJr in forum Specialized
    Last Post: 04-07-2004, 02:13 PM
