I'm trying to get the right adaptors (the first time) to mount my new brakes, and because I'm ordering other stuff from Jenson, I'd like to get them there if I can.
Front brake: Shimano XT M785 caliper (74mm hole spacing, post mount type)
Fork fork: 74mm posts
Front rotor: 180mm
Front adaptor: http://www.jensonusa.com/Shimano-F180PP2-Disc-Brake-Adaptor
Is this the right adaptor to use?
Rear brake: Shimano XT M785 caliper (74mm hole spacing, post mount type)
Rear frame mount: 51mm tabs
Rear rotor: 160mm
Rear adaptor: http://www.jensonusa.com/Shimano-74mm-To-51mm-Rear-Brake-Adapter
I think this is right, but it's out of stock till August, what else might work?
They have this which seems like a 51mm tab mount to 74mm post adaptor, but it says it's for forks (front) and I need a rear adaptor:
http://www.jensonusa.com/Shimano-F160PS-Disc-Brake-Adaptor
I'm starting to regret getting the 160mm rear rotor, I didn't think it would be such a long lead time to get adaptors for this? Should I try to return the rotor and get an easier to adapt 180mm rear rotor?
Front rotor: 180mm
Rear rotor: 160mm
