Adapter switching?- Mtbr.com
Results 1 to 10 of 10
    Reputation: k1lluaA's Avatar
    Adapter switching?
    okay, so this is gonna be the thrid quesiton i ask this week... I am getting 7inch 180mm rotors for my stroker trails, and i need adapters... i have read 5 times now on these forums people saying that a 160mm rear adapter is a 180 front adapter for IS mounts.
    I have a 160mm rear brake right now, so do i only need to buy 1 adapter, the 180mm rear? or am i crazy? cause if i can save the 15$ im down..
    Thanks.
    2008 Kona Caldera
    "Today I saw my own son use a bicycle as a weapon....
    I seriously thought he was going to rape me"
    160 rear is 180 front. But try this: move the rear to the front to confirm your suspicion before ordering.
    ya...problem is that i dont have the 180mm rotors yet, im ordering them with the adapters...so how would i know if its right?
    2008 Kona Caldera
    Trust me. If it doesn't fit, I'll gladly say "Oops"
    hrmmm...though i do trust that everyone here has alot more experiance with brakes and stuff than i do, i think i might just spend the 14$ to be safe.. and then if they are swappable, ill have an extra incase i ever need one...
    2008 Kona Caldera
    Thanks for the help though
    2008 Kona Caldera
    Reputation: Mr Cabletwitch's Avatar
    160 rear = 180 front just discovered this myself the hard way.
    Quote Originally Posted by Malibu412
    Cableb!tch: living, breathing proof you can be right and.still be a dick.
    Reputation: boomn's Avatar
    yep, 160mm rear is 180mm front. I have an adapter that has both numbers stamped in to it right next to each other so you know
    hrm ill look at mine and see if there are nnumbers
    2008 Kona Caldera
    will an adapter from my avid bb7 work for my new formula oro k24 brakes? Bottom line, are these adapters compatible with other brakes? considering the size of the rotor is the same at 160mm. thanks
