7900 calipers with v-brake levers???- Mtbr.com
Results 1 to 2 of 2
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    Does anyone know if this works. The leverage ratio has been changed from 7800 so the old flat bar levers shouldn't work. Who knows for sure?
    Reputation: reformed roadie's Avatar
    Changed how?
    More leverage / less pull; or less leverage / more pull?
    (a few years ago, I would have probably known this, but my interests are now almost exclusively off-road.)
    I suspect that even if it has increased pull, as needed, it won't be enough...but like you said, who knows?
    good luck.
    PVD - question for you - how concerned should I be about a little DOT4 fluid seeping from a bleed valve of a Hayes EC brake lever onto my Easton Carbon bar?
