2007 Shimano XT Calipers with????- Mtbr.com
Results 1 to 5 of 5
    I have a 2007 Rocky Mountain Element 70 that came stock w/ Shimano XT disc brakes and the XT hubs w/ centerlock rotors..
    I would like to change the wheelset out to one w/ Chris king hubs and 6 bolt rotors..
    Is there any compatability issues with the current brake system, and going to a regular 6 bolt hub w/ out the centerlock hubs??
    I would like to get the wheels w/ out switching out the brake system too.. Also, if it is possible, is there anything I should be looking out for??
    Thanks in advance..
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    no problem at all.... just get 6 bolt rotors along with the new wheels..and you should be good to go (shimano also makes 6 bolt rotors)
    Thanks for the help!!
    Greatly appreciated!!
    I AM I AM
    Reputation: ducktape's Avatar
    Got 6 bolt shimano rotors on mine: RT75 is the model number for the 6 bolt version I believe.
    I believe shimano brakes work with other rotors too as they have a narrower braking path, but other brakes won't work with shimano rotors for the same reason.
