180mm rotors & XTR discs, think this would work???- Mtbr.com
Results 1 to 3 of 3
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    So, Anders in the Weight forum ran a FRONT IS mount XTR caliper on the REAR of his Blur and this enabled him to use a 140mm in the rear. So;
    Front XTR caliper + rear IS mount = 140mm rotor. Cool way to save weight.
    Would this mean that if one used a REAR IS mount XTR caliper up front, they'd get the clearance to run a 180mm front rotor???
    I ask this because I'm thining of building a Karate Monkey 29er and would like to run a 180mm front/160mm rear rotor set up with my XT/XTR hydro combo.
    Cheers and thanks in advance for any help or insight on this.
    Correct, rear IS mount caliper on the front = 180mm or +20mm depending on size.
    Hope discs will fit, 180mm not 185mm older style.
    Kam
    Kam is offline
    A hopped on pop.
    Great, thanks...
    Quote Originally Posted by Paul5s
    Cool, thank for verifying that thought. I'll try 160mm front and rear. If I feel that more power is really necessary, switching out the front caliper and buying 180mm rotor.
  1. Juicy Rotors with Cable Discs?
    By ScaryJerry in forum Brake Time
    Last Post: 01-29-2004, 06:22 AM
  2. Problems with Deore Discs
    By cowleyd in forum Brake Time
    Last Post: 01-26-2004, 09:57 AM
  3. Replies: 1
    Last Post: 01-13-2004, 10:47 AM
