My son is trying to decide between the Specialized Rockhopper, base model, and the Gary Fisher Wahoo. Any opinions or suggestions. the decision is driving me, and him, nuts.
Main difference seems to be the front shock?? Wahoo has two springs, one on each side. Rockhopper, a spring on one side and hydraulic damping on the other. What diff can that make?
Prices are equal.
Rockhopper Components:
  • FRONT FORK: SR Suntour SF9-XCR-LO, 80/100mm, 1 piece magnesium lower, alloy steerer, hydraulic damping w/ LO and preload adj., size-specific spring rates, spring assisted seal
  • FRONT DERAILLEUR: Shimano Altus, 34.9mm clamp
  • REAR DERAILLEUR: SRAM X-5, mid cage
  • SHIFT LEVERS: SRAM X4-R trigger
  • CASSETTE: SRAM PG-830, 8-speed, 11-32t
  • CRANKSET: SR SunTour, Octalink spline
  • BOTTOM BRACKET: Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
  • RIMS: Alex RH 26, alloy double wall, CNC sidewalls, 26h front and 28h rear
  • FRONT HUB: Forged alloy, double sealed, ground race, steel QR, 28h
  • REAR HUB: Shimano RM30, forged alloy, double sealed, ground race, cassette, 32h
WAHOO
  • Front Shock: Suntour SF9-XCM-V2, 100mm travel, custom G2 Geometry 46mm offset crown, hydraulic lockout
  • Shifters: Shimano ST-EF50 8spd (integrated with brake levers)
  • Front Derailleur: Shimano Altus
  • Rear Derailleur: Shimano Deore M591
  • Cassette: SRAM PG830 11-32 8spd
  • Bottom Bracket: FSA BB-7420ST
  • Crank Set: Shimano FC-M361 42/32/22
  • Wheels: Alloy FM31, Shimano RM30 hubs, Bontrager Camino rims 32h
  • Tires: Bontrager Jones XR 26x2.2 rear/ 2.25 front
