Results 1 to 6 of 6
    Nov 2018
    small dents. should i be worried?
    I have some small dents on the bottom right of my top tube from when I was working on it . At most 1cm deep. Would you guys think this would compromise the integrity of my frame? It's a 6061 aluminum frame. If anything I mostly do regular all mountain riding.
    small dents. should i be worried?-l.jpgsmall dents. should i be worried?-thumbnail.jpg
    Reputation: supersedona's Avatar
    Dec 2012
    Being that they are not edgy or gouged I would venture to say that they are fine. I have seen worse than that still maintain structural integrity. If they had gouges or sharp dent creases they could produce a higher stress concentration and sooner crack than the rest of the frame. Regularly inspect the areas for cracks (like when you wash it), but I wouldn't retire it just yet.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by MarcReyes View Post
ID:	1225781Click image for larger version.
    It's your fault and it won't fail instantly if it does. So it is what it is and don't obsess over it. Top tubes aren't super stressed frame members, and those dents don't have any massive stress risers... so it's probably fine. Among aluminums, 6061 is pretty tolerant of abuse, for whatever that's worth.
    Worrying about it won't do you any good, so don't. It probably doesn't matter.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Reputation: justwan naride's Avatar
    I have a much deeper dent on the side of my top tube from falling on a rock garden. Bike's been fine and this happened 5 years ago. Alu frame. I've also seen plenty of dented chainstays on FS bikes that have no problems.
    Btw, you mean 1mm deep right? These don't look anywhere close to 1cm, besides I don't think the metal would have deformed that much without failing.
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    I wouldn't worry about it. Just keep an eye on it. I bought this 6061 hardtail bike used with this dent in the downtube. I put a similar dent in the other side in a crash shortly after buying the bike. I have since put 4400 hard trail miles on it, including several races, and have had no issues.
    Dec 2013
    Your frame is more likely to fail at the welds
    Dents are worse where the frame is loaded under compression than tension, as it could lead to buckling. I wouldn't worry though.
    Sent from my SM-G950F using Tapatalk
  1. Pull small dents out of steel frame?
    By Jason Rides Bikes in forum Bike and Frame discussion
    Last Post: 09-12-2018, 12:39 PM
  2. Replies: 17
    Last Post: 07-26-2013, 07:22 PM
  3. Dents, warranty, and should I even care?
    By bclagge in forum Specialized
    Last Post: 11-16-2012, 02:56 PM
  4. Dents when should you worry?
    By Lanegan in forum Downhill - Freeride
    Last Post: 03-27-2008, 12:55 PM
  5. Small dents in rim: how to fix?
    By dinger in forum Wheels and Tires
    Last Post: 07-22-2004, 08:50 AM
Members who have read this thread: 51
