Results 1 to 12 of 12
    Dec 2013
    Pull small dents out of steel frame?
    I know there are some ways to pull out dents out of car body panels and such, but is there an effective way of pulling small dents out of round tube bike frames?
    I have an o.g. Soma Groove 26" frame, never been built, but does have a small dent in the top tube that I think would be rad if I could pull it out. Not one to worry about structurally, more of a aesthetic thing.
    Deflated - buy parts to sell parts to buy more parts.. bikes are my drug of choice
    FATTrailer for the kiddo
    Nov 2014
    how about using bondo?
    Cycologist
    Reputation: chazpat's Avatar
    Quote Originally Posted by Rango View Post
    I think that's the way to go. I had a steel frame with some small dents and the guy who powder coats for me filled them.
    Quote Originally Posted by Oh My Sack! View Post
    Remember, there's always quilting and knitting if pedalling becomes too tough.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    considering the force needed to create the dent, i'd bet it's next to impossible to pull it...
    Reputation: FLYINW's Avatar
    Apr 2016
    Take it to a body shop and see much they'd charge to pull it.
    https://www.youtube.com/watch?v=vEyE8PibVDs
    Reputation: dbhammercycle's Avatar
    I tried a few different things to pull out a small dent in the top tube of my frame, none worked and the paint has a bunch of lil spider cracks from where I used dry ice... yeah that didn't work. I read about using wood blocks, pressurizing the tube to push out the dent (not gonna try that), even pouring water in the tube and freezing it yikes. In the end, if you want it to look new you will have to take it to someone to remove paint, fill (bondo or perhaps a braze fill) and then off to repaint. I used a thin coat of clear nail polish to cover the clear coat cracks in the paint job and kept riding. I figured it'll get other dents since I'm using it and the one that bugs me will fade amongst the rest.
    This dent occurred as I was building up the bike, even before I put a chain on and swung a leg over... set it down on the ground to adjust the stand and the bike f'in rolled and fell over. I know the pain... Anyway, if this is wall art repair the dent. If this is to be ridden, what are you waiting for?
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Dec 2013
    Quote Originally Posted by dbhammercycle View Post
    All the other projects in my garage and storage shed to get done! haha, it is never ending, waiting for a bike friday tikit to come back from bike friday, got a cargo frame that i'm in emails with a local powdercoater about, thinking about building a different rear wheel for my pugsley, you know, the usual stuff...
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Dents and removing them?
    Why bother?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    https://www.youtube.com/watch?v=JTDeXG0kweA
    may help reduce the dent so you can use less bondo
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    That's a good video, I've only seen that done with wood block rather than the aluminum blocks.
    Reputation: vikb's Avatar
    Just put a sticker over top of it. Seriously.
    Safe riding,
    Vik
    www.vikapproved.com
    Jan 2009
    Quote Originally Posted by FLYINW View Post
    I dunno about that on a steel frame due to most of them being heat treated, the tubing that is. You'd lose the properties from the original treating but since its steel you don't lose as much. I think as localhost mentioned/posted the vid for frame blocks, that is probably as good as it gets, then a small amount of bondo, etc will cover the rest.
  1. Replies: 17
    Last Post: 07-26-2013, 07:22 PM
  2. Is a steel frame a steel frame, a steel frame?
    By coffeegeek2112 in forum Bike and Frame discussion
    Last Post: 10-21-2007, 12:43 AM
  3. Is a steel frame a steel frame, a steel frame?
    By coffeegeek2112 in forum Frame Building
    Last Post: 10-20-2007, 10:54 PM
  4. Small dents in rim: how to fix?
    By dinger in forum Wheels and Tires
    Last Post: 07-22-2004, 08:50 AM
  5. Bottom-pull FD on top-pull frame?
    By >>ECB<< in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2004, 03:12 AM
Members who have read this thread: 68
