please help- Mtbr.com
Results 1 to 3 of 3
Thread: please help
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    please help
    which one would be the better choice???
    FSR XC Pro Specs
    FRAME FSR M4 butted frame w/ ORE downtube, sealed cartridge bearing pivots, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 100mm travel
    REAR SHOCK Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.0x1.6"
    FORK Rock Shox Reba SL, 100mm, air spring, lock out, ext rebound adj, alloy steerer
    HEADSET 1 1/8" threadless, black steel cups, loose ball bearings w/ seals
    STEM Specialized adjustable rise, OS 31.8, 3D forged
    HANDLEBARS Specialized XC low rise 31.8mm OS bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm width
    TAPE / GRIPS Specialized MTB, dual density
    FRONT BRAKE Avid Juicy 3, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
    REAR BRAKE Avid Juicy 3, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL: 185mm rotor
    BRAKE LEVERS Avid Juicy 3 hydraulic
    FRONT DERAILLEUR Shimano FD-M580, LX, top swing, dual pull, 34.9mm clamp
    REAR DERAILLEUR SRAM X-9, 9-speed, long cage
    SHIFT LEVERS SRAM SX-5 trigger, 9-speed
    CASSETTE / FREEWHEEL Shimano HG50, 9-speed, 11/34t
    CHAIN Shimano HG73
    CRANKSET Custom Shimano Hollowtech, Octalink XT Spline
    CHAINRINGS 22s/32s/44A 4mm thick outer, 4 bolt 104/64mm
    BOTTOM BRACKET Shimano ES-25 Octalink Spline, 68mm shell, 118mm spindle, 50mm chainline
    PEDALS Shimano 505 SPD
    RIMS Mavic X117 Disc, 26", 32h, black, presta valve
    FRONT HUB Specialized disc, sealed cartridge bearing, high/low flange, 32h
    REAR HUB Shimano M-475L disc, 32h, 8/9-speed, alloy QR
    SPOKES 1.8mm stainless, black, brass nipples
    FRONT TIRE Specialized Resolution 26x2.0", 120TPI, aramid bead, dual compound
    REAR TIRE Specialized Resolution 26x2.0", 120TPI, aramid bead, dual compound
    TUBES Specialized Ultralight 26x2.0", presta
    SADDLE Specialized BG MTB, hollow Cro-Mo rails
    SEAT POST 2014 butted alloy, black, 30.9 x 350/400mm
    SEAT BINDER Alloy collar with QR, 34.9mm clamp ID, black
    NOTES Protective clear coat, derailleur hanger, reflectors, owners manual
    Stumpjumper FSR Comp Specs
    FRAME FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
    REAR SHOCK Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.75x1.75"
    FORK Fox Float 120 RL, 120mm, rebound/compression adj, lock out, alloy steerer
    HEADSET 1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
    STEM Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
    HANDLEBARS Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
    FRONT BRAKE Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
    REAR BRAKE Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL 185mm rotor
    BRAKE LEVERS Avid Juicy 5
    FRONT DERAILLEUR Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
    SHIFT LEVERS SRAM X-7, aluminum trigger 9-speed
    CHAIN SRAM PC-951 w /Power Link
    CRANKSET Truvativ Stylo, 2pc crank/BB
    CHAINRINGS 22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
    BOTTOM BRACKET Truvativ GXP, sealed outboard cartridge bearing
    PEDALS Shimano M-520 SPD
    RIMS DT custom for Specialized X430, 24mm w/eyelets, 32h
    FRONT HUB Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
    REAR HUB Shimano M-525 disc, 32h, alloy QR
    SPOKES DT Swiss 1.8mm stainless, black, alloy nipples
    FRONT TIRE Specialized Resolution Pro 26x2.1", 120TPI, aramid bead, dual compound
    REAR TIRE Specialized Resolution Pro 26x2.1", 120TPI, aramid bead, dual compound
    SADDLE Specialized BG Rival, hollow Cro-Mo rails
    SEAT BINDER 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
    Reputation: Orca's Avatar
    depends on what you want to do with it.
    but, from the specs, it looks like the second bike has better components...like brakes, shifters, wheels, rear disc hub, and arguably the front suspension....
    Success is a lousy teacher. It seduces smart people into thinking they can't lose. - Bill Gates
    Calm Like a Bomb
    thanks for the reply orca...i should have added:
    i'm 5'7" 225lbs...the trails around here are very rocky, technical single track for the most part...they can get fast as well...some good drops in some areas...other trails are a little more stumpy...i do plan on riding it hard though...well as hard as i can
