Painting a carbon frame- Mtbr.com
Results 1 to 6 of 6
    Nov 2019
    Recommendations on videos or articles to follow? Main concern is stripping the old paint. Iím planning to just scuff it to avoid damaging the carbon.
    Any recommendations appreciated.
    Oct 2007
    Unless you are a professional painter with professional equipment it is always better not to strip the old paint, just sand it well for good paint adhesion. The original paint makes a much better base for your paint then any primer you are likely to use at home. If you are just using spray cans, the best thing you can do for durability is get a 2K clear (they come in matte or gloss) to coat the paint, I use Spraymax and get it from Amazon . Just keep in mind you must use a respirator mask as 2K paint is really bad for you. If you want a glossy finish you will need to learn how to color sand to smooth out any orange peel in the paint.
    2015 Niner Jet 9 Carbon
    2015 KHS Sixfifty Team
    2019 Salsa Warbird
    2019 Canyon Endurace
    1987 Haro RS1
    Nov 2019
    Quote Originally Posted by ljsmith View Post
    Thanks for the heads up. It will be painted by a friend who paints cars. So Iím confident in his abilities to wet sand and spray with a professional gun. He has sanded and painted carbon fiber hoods on vehicles that came out fine, so Iím sure this isnít much different. Just wanted to confirm if there was anything different.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    How about posting up a photo your bike after complete? Maybe even a before and after?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Reputation: chrisx's Avatar
    A 1.3 mm car spray gun is not the best for a bike. Can you get ahold of an airbrush with a .3 mm nozzle?
    Magically Delicious
    If you have not heard of him, look up Martin Gray. Bike painter extraordinaire. He has a significant YouTube presence.
  1. Painting Raw Carbon Fiber Frame
    By Dooms101 in forum General Discussion
    Last Post: 09-09-2016, 09:38 PM
  2. Painting Niner Carbon fork to match frame.
    By ozzybmx in forum Custom Builders & Other Manufacturers
    Last Post: 09-30-2013, 06:06 AM
  3. Carbon frame painting
    By nyrdrms in forum Bike and Frame discussion
    Last Post: 02-08-2012, 10:17 PM
  4. Painting a carbon frame
    By DirtyR in forum Frame Building
    Last Post: 02-04-2012, 10:10 AM
  5. Painting a carbon frame
    By Guernica in forum General Discussion
    Last Post: 11-11-2011, 02:39 PM
Members who have read this thread: 51
