Paint Scratched On Aluminum Frame- Mtbr.com
Results 1 to 6 of 6
    Sep 2016
    Thank you!
    nvphatty
    Guest
    Given it's location no worries about future damage or corrosion.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    added a word
    It should be fine. OTOH, I would check your front derailleur adjustment. A chain slipping off should be a very rare occurence, if not altogether unheard of if your front derailleur is properly adjusted. When your inner chainring gets too worn, it will suck the chain in into the chainstay from below as it comes off of (or tries to at least) the bottom of the chainring. But your bike is pretty new, so that is why I think your front derailleur adjustment is likely to be the culprit.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Quote Originally Posted by jeffj View Post
    It should be fine. OTOH, I would check your front derailleur adjustment. A chain slipping off should be a very rare occurence, if not altogether unheard of if your front derailleur is properly adjusted. When your inner chainring gets too worn, it will suck the chain in into the chainstay from below as it comes off of (or tries to at least) the bottom of the chainring. But your bike is pretty new, so that is why I think your front derailleur is likely to be the culprit.
    What's a front derailleur????
    Bicycles donít have motors or batteries.
    Ebikes are not bicycles
    nvphatty
    Guest
    Quote Originally Posted by mtnbikej View Post
    stop
    R.I.P. DogFriend
    Something mortals use to help them climb up steep hills. Not anything you need to concern yourself with
  1. Replies: 9
    Last Post: 10-20-2016, 05:23 AM
  2. When to re paint aluminum frame?
    By SSChameleon in forum Bike and Frame discussion
    Last Post: 12-16-2014, 09:16 PM
  3. Front range body shop to paint an aluminum frame?
    By Streetdoctor in forum Colorado - Front Range
    Last Post: 04-21-2014, 07:11 AM
  4. Seattle area aluminum frame paint removal
    By zurC atnaS in forum Washington
    Last Post: 01-21-2011, 01:41 PM
  5. Paint removal on an aluminum frame
    By jekyll2003 in forum Frame Building
    Last Post: 01-04-2011, 09:10 AM
