    Jun 2018
    New question here. New Ibis Ripley Configuration Help
    I just received my new Ibis Ripley LS (gx build) and want some input on configuring the suspension and tire pressure.
    I weigh 190-195 and am 5'8".
    The bike has the Fox Float 34 Fork and Fox Float DPS.
    After reading the manual, I think I should set everything to:
    • Fox Float 34 Performance Series: 90
    • Fox Float 34 Performance Series Rebound: 5 clicks
    • Fox Float DPS Performance Series EVOL: 220
    Do those numbers seem right? Also, how exactly does the Rebound configuration work? Start all the way to the left and then listen for clicks moving clockwise?
    Rear tire: Maxxis Agressor 29x2.50wt
    Front tire: Maxxis Minion DHF 29x2.50wt
    I was thinking of starting out with 30psi. Does that sound right?
    BTW I ordered it from Velorangutan and the transaction and price was awesome. Wes has been fantastic to deal with.
    I have the 2017 ripley with Fox facory shock and and a Fox 34 Rythm fork.
    Running 72 psi fork rebound 4 clicks from full open
    Frame 185 psi rebound 4-5 (still need to keep tweaking here but overall really good)
    I wiegh proably 185 give or geared up no calmebak.
    XC, Road, XXC, Endurance, Mtn, All-Mtn, Cross, Gravel, just go have fun on 2 wheels!
    Nov 2016
    I'm 200lbs and run 85psi fork w/4 clicks from open, 190psi rear 6-7 clicks rebound.
    I have the same tire setup on my Ripley w/942 wheelset. I'm running 17-18 front and 24-25 rear with no problems, never even close to a rim strike through fast rocky descents. Can probably go a little lower.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Normally, rebound settings are specified from fully closed, that's turned fully clockwise, which provides the most damping. Count clicks from there to get the desired rebound damping. Higher fork pressure usually means more rebound damping is needed. For starting pressure, set sag, then vary a bit from there as preferred. There are many good youtubes on how to set up suspension.
    Sag is a good starting point as it takes in to account rider weight, leverage ratio (rear shock), weight distribution of the bike, and is independent of gauge accuracy.
    Do the math.
  1. 2018 Ibis Ripley GX vs. 2017 Ripley GX
    By dddfg44 in forum 29er Bikes
    Last Post: 06-28-2018, 04:53 AM
  2. Ibis HD3 Final Configuration: 23.3 pounds
    By Davide in forum Weight Weenies
    Last Post: 03-26-2017, 08:56 AM
  3. help with 10sp road/mtb configuration
    By Stupendous Man in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2016, 10:44 AM
  4. HELP! In what configuration should I sell my bike?
    By vincavinz in forum General Discussion
    Last Post: 07-18-2012, 07:03 PM
  5. I Need Help Deciding on My Upgrade/Configuration
    By Velofreak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-13-2008, 11:07 AM
Members who have read this thread: 29
