Results 1 to 10 of 10
    Jan 2017
    We the people ... I can't figure out what headset bearings to get.
    I have the headset information from the manufacturer.
    HEADSET 1-1/8"" upper, 1-1/2"" lower, threadless, Campy style, cartridge bearings
    But regardless, I try and try googling this to no avail. I can not figure out where what I need is. I absolutely refuse to take it to my LBS. He messes literally everything up, things that I end up fixing on my own and I'm tired of it. I get blamed by him for crap that's his fault. He tries to "educate" me with clearly false information. Enough of my ranting. My bottom headset bearing has extreme play so it needs to be replaced. I'm able to find threadless bearings close to that spec, but I know that campy styles are different. Something about the angles being different on the chamfers or some crap. (There's next to no information on the internet for what a campy style is.) I really don't want to spend more than $25 for a set of the bearings. If someone could link me with a product page, I would be extremely grateful.
    Oh and if it helps, it's a 2016 Specialized Fuse 6fattie pro.
    Turns right to go left
    Reputation: 410sprint's Avatar
    Oct 2012
    Here:
    https://www.canecreek.com/headset-fit-finder
    the 36 deg bearings are now considered obsolete and the current standard is 45deg.
    Jan 2017
    Quote Originally Posted by 410sprint View Post
    Here:
    Thanks, but I already looked through that one and the chris king one. Neither had my bike (again, 2016 Specialized Fuse Pro 6fattie)
    I'm 94.3% that bike uses a IS42/28.6/H9 | IS52/40.
    That's Cane Creek number for the upper and lower set in their 40 series. The meaning of the numbers is on their web page.
    What makes you think there is anything "campy" about this?
    Oct 2017
    To be fair to the OP, this is a copy/paste from Specialized's website. I don't understand the 'Campy' reference either, but that is coming from Specialized and not the OP. I think you are probably right on the headset though providing Campy indicates Italian according to Park Tools website.
    To the OP, I would call a different Specialized shop just to confirm, since you don't trust your local one.
    Reputation: Lone Rager's Avatar
    Dec 2013
    I've run into this with Specialized too. I'm guessing Campy style means 45/45 degree bearings rather than 36/45...but I could be wrong on that one. Best thing is to yank them out and measure ID/OD, thickness and inner and outer chamfer angles.
    Do the math.
    Oct 2012
    Quote Originally Posted by shitbike View Post
    While your specific bike is not listed on the CC or King headset finders, you will see that all of other 2016 Specialized MTB's (and road bikes) with 1-1/8"" upper, 1-1/2" lower IS headsets used IS 42/28.6 | IS 52/40 bearings. Both top and bottom are 45deg angle. As already stated, the 36 deg. angle bearings are obsolete and have not been used for a long time. This is what you need.
    Still unsure? You can quickly verify this by reaching out to Cane Creek or King. They are great folks and will be happy to help.
    Jan 2017
    Thanks guys, i'll try your suggestions.
    Jul 2018
    Hi there,
    I am also interested for changing bearings in headset of specialized enduro evo 2012. Did you try these suggestions ( 42/28,6 for top and 52/40 for bottom) ?
    Jan 2017
    Quote Originally Posted by kewre View Post
    Hi there,
    Honestly, I haven't. If it gets more problematic (which it hasn't, then I'll give it a shot.) The bearings are still bookmarked.
  1. Replies: 3
    Last Post: 04-03-2016, 08:47 AM
  2. Replies: 31
    Last Post: 10-31-2015, 05:52 AM
  3. Northern PA - Help me figure out how to get "here"
    By max-a-mill in forum Pennsylvania
    Last Post: 01-16-2014, 06:59 AM
  4. How can i figure out what typ of spring i have to get
    By Scruffynerfhearder in forum Downhill - Freeride
    Last Post: 11-28-2011, 10:46 AM
  5. cant figure out how to get my wheel on straight
    By Fatboy209 in forum Beginner's Corner
    Last Post: 03-17-2011, 10:35 AM
Members who have read this thread: 18
