How can I fix this dented ISCG tab.- Mtbr.com
Results 1 to 5 of 5
    Hi guys, I have a problem with my frame, one of the ISCG hole is dented, can those metal shops fix it for cheap or am I stuck with 2 holes for the chainguide?
    Here's a picture.
    Reputation: akacoke's Avatar
    not a very big deal, you can drill the top part round , then re tap it. wont take very long to do it if you have the proper tool
    seriously you pic is too big
    I've never done anything related to this, are the tools expensive?
    Ride Responsibly
    Reputation: LWright's Avatar
    Yes, it would be an easy fix for most any person with a mechanical aptitude.
    Could remove the "raised" sections with a flat, smooth file. Then remove most of the messed up thread with a small rat-tail or chain saw type file. Then use a tap or even just a longer bolt started from the back-side to re-thread the mangled sections.
    The aluminum is easy to remove. Might get by with just a bolt run from the backside, a "Self-tapping bolt" would help.
    ah thanks for the advice, i'll see if home depot got the right bolt with the correct TPI spec.
