Help comparing specs?- Mtbr.com
Results 1 to 3 of 3
    Feb 2007
    Would anyone be interested in comparing these two specs? They are for the 2006 vs 2007 Iron Horse MKIII Comp.
    2006
    Frame: 5" TRAVEL DW-LINK TRAIL FRAME, 1 1/8' ZERO STACK HEAD TUBE, REPLACEABLE DERAILLEUR HANGER
    Fork: ROCK SHOX REVALATION 409, DUAL AIR, 130MM TRAVEL
    Rear Shock: MANITOU RADIUM R AIR, 7.5" EYE TO EYE X 2" STROKE
    Front Derailleur: SRAM X-GEN
    Rear Derailleur: SRAM X.7
    Shifters: SRAM X.7 TRIGGER
    Brakes Levers: HAYES HFX-9-XC
    Brakes: HAYES HFX-9 DISC W/ 6" ROTOR
    Chain: SRAM PC-951 W/ POWERLINK
    Crankset: TRUVATIV FIREX, GIGA-X
    Cassette: SRAM PG-950, 11X34, 9 SPEED
    Pedals: CRANK BROS CANDY C CLIPLESS
    Bottom Bracket: TRUVATIV GIGA-X
    Headset: FSA ORBIT Z, SERO STACK
    Saddle: WTB ROCKET V COMP
    Seat Post: EASTON EA30
    Handlebar: EASTON EA30 DB LOW RISE, 31.8MM CLAMP
    Grips: RUBBER
    Stem: EASTON EA30, 31.8MM CLAMP
    Tires: WTB WEIRWOLF 2.35" DNA CASING
    Wheelset: 32 HOLE ALLOY DISC HUBS, DT SWISS X455 RIMS, DT SWISS COMP SPOKES 1.8/2.0
    Weight: N/A
    Color: PEARL GREEN
    2007
    http://www.ironhorsebikes.com/MKIIIComp.html
    Thanks for your help
    Reputation: MrKalentine's Avatar
    If nobody replies I can at least tell you this:
    2007 SRAM x.5 = 2006 x.7
    2007 SRAM x.7 = 2006 x.9
    2007 SRAM x.9 = 2006 x.0
    2007 SRAM x.0 = 2007 x.0
    And they protect you from meteors.
    Well, that's the word on the street.
    Cuánto pesa?
    Reputation: Jake Pay's Avatar
    Sorry Qben..Short high jack...................
    07' SRAM X9 RD has a similar blue print as the 06' X0 but not the same materials..
    07' X9 weight: 227g (medium cage)
    06' XO weight: 197g (medium cage)
    Over an ounce of fat
    Jake..
