Results 1 to 11 of 11
Thread: Headset
    May 2018
    Headset
    I have a Diamond Back Responce xe and Iím trying to get a new headset.I have tried Fsa the pig 1 1/8 and The big Fat pig .1 1/8 too small for steer tube and 1.5 is the same size so doesnít fit anybody know what size head set will fit this bike .Im thinking 44 mm .
    mbtr member
    Reputation: scottzg's Avatar
    You most likely have a 1.125 straight head tube. Tapered fork is a no-go, no matter what headset you use.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    RAKC Industries
    Jan 2017
    Nope 44mm semi integrated. Extremely common before tapered fully took over.
    He already said fsa pig headsets don't fit, too small. Which then makes it clear it's not a 1.125 (standard 1 1/8 straight head tube) as that is exactly what the FSA Pig headsets are for.
    Tapered is no problem with the lower cup adapter that allows for 1.5 tapered.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    mbtr member
    Quote Originally Posted by RAKC Ind View Post
    I think you misread his post- he said 1.125 don't fit the steerer tube. Certainly one of us is misreading his alphabet soup.
    OP, post a pic of the front of your head tube with the headset cups showing.
    Mikhail Kalashnikov
    RAKC Industries
    Jan 2017
    Yeap we are cause I missed that. Think brains he's confused on terms so nether one of us can follow it right.
    mbtr member
    Right?! He's not even formatting his periods reliably.
    Mikhail Kalashnikov
    Dec 2017
    Quote Originally Posted by WillS. View Post
    What year is your bike?
    May 2018
    I think itís 2014
    Dec 2017
    I think itís 2014
    Is the bottom bearing cup external? If so, it should be a ZS49/28.6 | EC44/30 according to the Cane Creek headset finder. The first part is for the upper headset and the last part for the bottom. Buy a cheap caliper and measure it to be sure.
    Out spokin'
    Dec 1999
    Quote Originally Posted by Sparkman999 View Post
    Or just go to a bike shop.
    =sParty
    disciplesofdirt.org
    RAKC Industries
    Jan 2017
    I think as mentioned he's trying to cram a tapered fork into an old straight 1 1/8 head tube bike. I looked at pics of the bike and it looks like 44mm semi integrated (I watch some reviews too). Which is why he's probably having issues
  1. Replies: 6
    Last Post: 11-19-2012, 04:58 PM
  2. rz140 headset? headset confusion?
    By akiracornell in forum Cannondale
    Last Post: 09-21-2012, 06:41 PM
  3. Replies: 15
    Last Post: 10-03-2011, 11:41 AM
  4. Threadless headset and Integrated headset?
    By ricky916 in forum Bike and Frame discussion
    Last Post: 07-24-2011, 12:07 PM
  5. 1.5 inch headset reducer shims vs. "full" reducer headset
    By pfcnguyen in forum Downhill - Freeride
    Last Post: 03-21-2011, 11:55 AM
