Results 1 to 11 of 11
    Head tube OD not round
    Hi all,
    I recently bought a close out frame, Ventus sentier vrx, from chain reaction cycles. The head tube top and bottom OD is not perfectly round. There are visible indentations at the front close to the 12 o clock position. First 2 pics are the top, last 2 pics are bottom.
    Should I be concerned? Is this a big problem?
    I planned on ordering a cane creek 40 zs headset to use with this frame
    Wanna ride bikes?
    Oct 2013
    If you're referring to the small dent on the outside of the headtube, I wouldn't worry about it. If you took accurate measurements of the ID of the headtube and it's out of round, that's a problem.
    Your ZS headset presses into the inner part of the HT and doesn't touch the outer. If the headtube isn't bent/ovalized, it's not a problem.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: Lone Rager's Avatar
    Dec 2013
    Not a huge thing. It'll make pressing in the cups harder. You may want to have the LBS ream the ID to size.
    Do the math.
    Jan 2009
    I have built up several bikes starting with the bar frame, and it's always a good idea to ream it properly. it's lousy that manufacturers don't do this from the factory. my Jabberwocky was so bad that the bottom cup would not press into the head tube flat at all until we reamed it. not all bike shops will have the right tools for that as they are expensive and are rarely used.
    I don't see the big deal with the OD though.
    Oct 2018
    That head tube has been faced already. You can see the machining swirls on the inside and face, so it’s stil parallel. The little ding on the outside edge may have distorted the tube diameter slightly but before recutting the inside try installing the the headset. It may still seat fine if a proper threaded press is used.
    Metallurgically, the molecules “remember” where they should be and can be coaxed back with pressure from the opposite side of the ding. Steel is better than aluminum but I doubt there’s a problem here.
    Wanna ride bikes?
    Oct 2013
    Most likely those machining marks were there before the frame was welded, painted, or dented. I doubt that frame has been reamed.
    I do agree it's probably fine though.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Oct 2018
    Ummm, the ridge left by the bottom of the cutting tool after reaming is visible inside the head tube.
    Quote Originally Posted by *OneSpeed* View Post
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by Reconnaissanceman View Post
    How do you know that was done after the frame was built?
    I'm not saying for sure I know it wasn't, I don't, I'm just speculating. I'm also not saying it was never machined, clearly it was.
    The reason head tubes and BB's (at least threaded ones) need to be reamed and chased is because most of that is done before the frame is welded and it often needs to be cleaned up prior to assembly due to warping or other imperfections.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Thanks for the info everyone. I took it to the lbs and got a new headset pressed in. They said the dents shouldn’t be a problem
    No Clue Crew
    Apr 2005
    Yep, as you say, long as the cups press in properly, I wouldn’t worry about it.
    Just like a raindrop, I was born to fall.
    Oct 2015
    Well an aluminum headcup would likely deform to fit an oval headtube ID too ... they could both end up slightly oval
  1. Weehoo iGo 2 - square tube kickstand on older round tube chassis
    By mauric6943 in forum Families and Riding with Kids
    Last Post: 06-09-2017, 10:54 AM
  2. When is "round" not round??
    By slohr in forum Singlespeed
    Last Post: 05-26-2016, 06:43 PM
  3. Oval to round to oval to round to...
    By Lenny7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-28-2015, 07:11 PM
  4. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  5. 2012 Air9 Head tube / head set questions
    By Nooge in forum Niner Bikes
    Last Post: 12-27-2011, 03:51 PM
Members who have read this thread: 48
