Results 1 to 12 of 12
    Reputation: jpc6000's Avatar
    Feb 2018
    New question here. Front Suspension
    For a titanium 29er frame
    I need a suspension fork.
    The producer deliver it with a rigid titanium fork
    If I want to place a suspension fork in it, what travel I can use?
    Or how can I know it
    This is the frame
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Do you has google?
    Jan 2009
    Link to frame with geometry?
    Get a fork with a similar A-C length to what the frame is designed to use.
    Is that a motorized fatbike?
    Feb 2018
    Feb 2018
    Cool-blue Rhythm suspension travel
    here the geometry of the frame
    what I have to do to know what the travel of the front fork
    Attached Thumbnails Attached Thumbnails Front Suspension-tita-frame-geometry.pdf
    Jan 2009
    465 mm is usually a sagged 80 mm travel 29er fork. I would ask the manufacturer what they recommend. On some frames, you can use a longer fork without screwing up the handling or risking breaking the frame.
    So my guess would be 80mm maximum.
    Feb 2018
    Hi,
    Thanks, the bike sellers don't give good advice
    not their frame bla bla bla, their resposibilty LOL
    I will use 27,5" 100mm rockshox SID WC offset 46
    27.5" suspension fork is smaller so I will hope it work.
    I have also ask directly to sram rockshox
    A 100mm SID will work fine if it's what you intend to use. 487mm A2C, once sagged would get you exactly where you want to be.
    To be clear though, it looks like this geometry is intended for 27.5x3.0" tires. There's a B+ version of the 27.5" SID and a normal (non-plus) version with less tire clearance.
    If you don't intend to run 27.5x3.0 tires or as a 29er, 60mm of BB drop will put you pretty low with 27.5x2.3".
    Feb 2018
    If I can find Tire Co Speedster - 27.5" x 3.0" this tires want to use
    The fork I prefer: RockShox SID World Cup 100mm
    Which fork can I use?
    Wheels are 27.5 "
    The forks 27.5 inches 27.5 + / 29 inches and 29 inches
    Maxle 15x100 and 15x110mm boost
    Offset 42/46/51
    Is there a difference between 27.5" - 27.5 +/29 inch and 29 inch forks
    I need this fork but can not be found:
    27.5 + / 29 inches 15 x 110mm boost offset 46
    The best I found is:
    1. RockShox SID World Cup Solo Air OneLoc 27.5+/29 Inch Fork - 100mm - 51mm Offset - Tapered - Maxle Ultimate - 15x110mm Boost
    2. Rock Shox SID WC SA 2017 29" - matte black Oneloc Sprint 46mm - 15x100mm
    3. SID World Cup - Solo Air 100 29" BOOST - 15x110 - 51 offset
    Option 1 and 2 is offset 51mm, good with 27.5" wheels?
    Option 2 Waxle 100mm not boost can these fork 3.0" tires?
    Option 3 is 29" is this A2C or more?
    https://www.actionsports.de/rock-sho...8?sPartner=101
    https://www.actionsports.de/en/rock-...int-46mm-24136
    https://www.bike24.com/p2215423.html
    Feb 2018
    the bike fix fork 465mm
    when I take 27,5 Inch Fork - 100mm,
    Fork length (mm, axle to crown): 487 mm
    bike front + 23mm higher, ok?
    with 27,5+/29" fork +42 mm higher, ok?
    Manitou Magnum Pro 27,5" max tire 3.4"
    Is this good fork?
    Reputation: Curveball's Avatar
    Aug 2015
    Why would they use titanium for an e-bike?
    Is that even a tapered head tube?
    Riding Washington State singletrack since 1986
    Feb 2018
    It is the only frame for Bafang Ultra motor that I can buy, and have Rohloff speedhub dropouts.
    yes it is tapered head tube.
  1. Need Advice! Used full suspension vs new front suspension
    By tyrone in forum Beginner's Corner
    Last Post: 09-20-2017, 05:30 AM
  2. Replies: 207
    Last Post: 08-01-2016, 04:26 AM
  3. Replies: 4
    Last Post: 09-13-2012, 01:33 AM
  4. RDO rear suspension vs RIP 9 suspension
    By farmertan in forum Niner Bikes
    Last Post: 09-18-2011, 02:47 AM
  5. suspension, suspension
    By radnur22 in forum Bike and Frame discussion
    Last Post: 08-23-2011, 01:41 PM
