Frame painting question- Mtbr.com
    Cycologist
    Reputation: chazpat's Avatar
    New question here. Frame painting question
    I just had my Jamis Dakota XC (Reynolds 631) powder coated. The guy did not paint the edges of the head tube nor the bottom bracket shell. Is this typical? I'm not getting them faced. I know the headset and bottom bracket will cover these but I still worry they need protection, especially the bb shell. Are these ok to leave exposed or do I put oil on them to protect them (and attract dirt?) or something else? The edge of the seat tube was painted.
    chaz
    Former Bike Wrench
    You want those areas square, not covered in uneven paint. They should be faced, but if you don't I assume you will be using grease or anti-seize on the BB threads which will squeeze out and get on the ends too.
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Not coating the BB sounds like he knew what he was doing. It's really hard to get powder coating off of a threaded surface. Good luck
    A garage full of steel frames means happiness.
    Reputation: jpeters's Avatar
    Yeah he did his job
  1. Frame painting question
    By NEWORLEANS-YAT in forum Bike and Frame discussion
    Last Post: 11-23-2009, 01:11 AM
  2. painting frame by hand, how paint the words on frame?
    By BikeisLife in forum Bike and Frame discussion
    Last Post: 06-24-2008, 09:09 AM
  3. frame painting question
    By coghi in forum Downhill - Freeride
    Last Post: 12-04-2007, 11:15 AM
  4. Can Painting a Frame
    By smoFLASH in forum General Discussion
    Last Post: 07-27-2006, 04:23 PM
  5. Frame painting question
    By KavuRider in forum General Discussion
    Last Post: 12-27-2005, 08:08 AM
